浙江车网论坛 论坛首页 八卦热闻 停车难逼出小区奇葩占位妈妈(图)
查看: 984|回复: 6
停车难逼出小区奇葩占位妈妈(图)   [复制链接]
发表于 2013-5-24 07:34 |只看该作者 |倒序浏览 |打印
宁波飞虹新村一期是个老小区,建成近20年。小区住户现有300辆车,只有100个停车位,1∶3的供求关系——小区居民为了抢到个停车位,伤透了脑筋。最初不知是谁先起的头,有人开始提前占位子,门板、椅子、桌子、盆栽、拖把、树桩……但凡能停车的地方,都早早摆上了这些,以示先来先得。
  也有人私自装上地锁,在地上划个长方形,撒上白粉,再立一块牌子,上书:“×××××专用车位”;也有不好惹的,打出“禁止停车,后果自负”的警示标语。
  49岁的柳阿姨,在这个小区一住十多年,为人和气,平常很少出门。但自从去年女儿买了一辆车之后,柳阿姨被迫加入到抢车位行列。她采用的办法最吃力——搬把凳子占住车位,自己一直坐在凳子上。柳阿姨为此时常遭人白眼,也成了小区里最出名的一位占车位妈妈。
附件: 你需要登录才可以下载或查看附件。没有帐号?注册
Rank: 9Rank: 9Rank: 9
发表于 2013-5-25 06:17 |只看该作者
发表于 2013-5-27 07:19 |只看该作者
爱女心切嘛!
发表于 2013-5-29 06:49 |只看该作者
希望大家踊跃发言,我顶先
跑步机价格
5#
发表于 2013-5-29 12:12 |只看该作者
发表于 2013-5-31 09:58 |只看该作者
air max This Shark shows a HARDWARE screen having
This Shark shows a HARDWARE screen having at controller air max pas cher memory space storeroom together with readily louis vuitton bags logs onto to the majority portable computers (not works with Mac). The machine includes a UNIVERSAL SERIES BUS lead, controller carton, " dia. VGroove router little bit of, a couple of accommodate straight down louis vuitton bags clamps, supports for one Bosch Router Prada Outlet (the router comes separately), VCarve longchamp Expert 6. 0 software programs, louis vuitton plus a complimentary down loadable deal with plan.. Here are a few within the natural treatments intended for itch remedy WHEN I locate beneficial. So many people are numerous and never all of the tactics gets results for all. You Toms Shoes Sale will want to supply a lot of these eczema herbal treatments a oakley outlet go to learn precisely what is ideal suitable for you. Available louboutin shoes for you, I louis vuitton might usually dismiss each of the psychic readings through HWMonitor right up until tested as a result of additional usually coach factory outlet means. Have a look at alternative watch uses which include CoreTemp or perhaps SpeedFan
Related articles:
   coach factory "I noticed Baby Ruth at the conclusion with yo
   longchamp pas cher The overlong along with to be truthful uninteresting re-doing
   Prada Handbags Is there working lady inside your l
   longchamp pas cher Intended for usefulness
   louis vuitton sac Precisely why had been they frustrated
[url=http://www.contextualnews.com/coachoutletonline.html]coach purses outlet[/u
7#
发表于 2013-5-31 12:25 |只看该作者
太牛了!大妈!
GMT+8, 2025-11-11 17:25 , Processed in 0.024608 second(s), 13 queries .
