查看: 541|回复: 0
[落户上牌] aXKOTijwsUd [复制链接]
游客 发表于 2019-6-15 10:27 |倒序浏览 |打印
I'll call back later http://imagefap.in.net/ cfnm imagefap  - Consider it a back-door estate plan. Switching a 529plan's beneficiaries to another generation can trigger gift andestate taxes, so you have to be strategic. In the case above,for example, if your account had grown to more than $14,000, youwouldn't be able to move all of it to a beneficiary in the nextgeneration at once. But you could move $14,000 a year (indexedfor inflation) to a new beneficiary without even starting toreduce your lifetime gift and estate tax exclusion. To avoidhaving to change beneficiaries on a large account, you couldstart to switch the beneficiaries as soon as the next generationis born and they would still benefit from the long-termcompounding you set in motion.
GMT+8, 2026-1-3 12:56 , Processed in 0.020083 second(s), 12 queries .
