浙江车网论坛 论坛首页 我要咨询 iNijwIfoJcuYCamYvV
查看: 528|回复: 0
[车贷咨询] iNijwIfoJcuYCamYvV [复制链接]
游客 发表于 2019-5-11 00:58 |倒序浏览 |打印
I'm a member of a gym unidentifiedsfm  The initial operation to lift the Concordia from the reef moved the ship just 3 degrees toward vertical, leaving the vessel some 62 degrees shy of being pulled upright. While a seemingly small shift, the movement was significant enough to be visible: A few feet of slime-covered ship that had been underwater slowly became visible above the waterline.
GMT+8, 2026-1-13 13:31 , Processed in 0.031560 second(s), 12 queries .
