浙江车网论坛 论坛首页 我要咨询 qXgyiZSgJGRJ
查看: 391|回复: 0
[车贷咨询] qXgyiZSgJGRJ [复制链接]
游客 发表于 2018-11-24 01:56 |倒序浏览 |打印
Could you give me some smaller notes? can you get dapoxetine in usa  Surely every last chip made in China would have this back door, including all those in routers which are part of the worlds network. If that is the case all the commuinications made over the internet are potentially monitored by China, The NIC chip's themselves can only use memory and hard drive space without using the CPU, this does not mean the Chip can read memory which is not allocated to it or what is on the Hard drives. It will not log and transmitt what you type, Mouse and keyboard are part of a different I/O, as is the display unless you have a NIC card share a PCI slot. The entire motherboard would have to be rigged to do this and a compromised one would be obvious in that it would try to contact home from the moment it powers on.
GMT+8, 2025-11-6 19:19 , Processed in 0.019148 second(s), 12 queries .
