楼主: 阿拉蕾
杭州春日游人多   [复制链接]
41#
发表于 2013-1-31 04:45 |只看该作者
先顶后看~~
乔莎  骆驼
42#
发表于 2013-2-10 19:48 |只看该作者
哪个呦,发这么好的帖子,顶你
婵真
43#
发表于 2013-3-7 20:12 |只看该作者
共同发展!学习才会进步,谢了
醉枕江山
超级教练
44#
发表于 2013-4-9 11:11 |只看该作者
强烈支持。
沈阳新娘跟妆http://blog.sina.com.cn/88wedcom
45#
发表于 2013-4-25 08:07 |只看该作者
此贴有意思~
洪城网购 www.hcwgo.com
发表于 2013-4-30 02:39 |只看该作者
sale mbt shoes862469855
Remote
desktop installation can be performed in a few simple steps. When installing
remote desktop software it is important to keep security in mind.?
  There are many benefits to having
remoteconnection software set up on
your PC. Remotedesktop applications
make it possible to connect with your host computer from any other computer you
may be using at the time. For example, if you have been working on a project
from your home computer and need to access that information while you are
working, you can use a remote connection in order to gain access to the
information from your remotecomputer.
In order to install remote desktop software a few steps are required, but they
are very simple.
Remote Desktop Computer Requirements
In order to use ??software, there are a few basic requirements that must be met. The first
requirement is access to high-speed internet service. Remote desktop software
requires a steady connection in order to run, and a high-speed connection is
the best option,sale mbt shoes. In addition, a person will need to have a router that supports
port forwarding. There are several routers of this type available, and it
should be noted that firewall protection is also beneficial. A DynDNS account
will need to be created if using DSL internet service.
Step 1: Setup
The first step in setting up a ??will be to understand your router?s capabilities. A router
that already allows IP address forwarding and updates of dynamic domain
services will allow remote desktop software to be installed easily. Routers
that require the use of DynDNS will require an account to be set up with the
program. Using the computer that you wish to connect to you will create a
username and password, and you will then add a new host and create a username
for the host as well,mbt sandals.
Step 2: Allowing Remote Desktop
After the initial process of creating a
password and checking your router capabilities, the next step is to set up the
computer to allow remote access. To do this, click on ?my computer? and select
?properties.? Under this tab, you will see a box that says: ?Allow users to
connect remotely.? Check this box and your PC will be enabled to accept access
from a remote computer,http://mbtfootwearuk.webs.com/. In addition, setting up a password for
your Windows account will be necessary, which can be done through the control
panel,http://mbtonsale.webs.com/.
Step 3: Safety Features
There are certain precautions a person
should take when setting up their computer for remote access,http://cheap-mbt-shoes-uk.webs.com/. Setting up
firewalls is extremely important. This will block your computer from being used
by everyone, which could be potentially dangerous. Security updates should be
installed as soon as they become available, as this is the best way to keep
your data safe from hackers. Changing passwords at least once every three
months will also help keep your information as safe as possible. If you are
uncomfortable setting up the remote desktop software and its safety features,
then it is recommended that you contact a networking professional.
    Article Tags:
发表于 2013-5-10 10:58 |只看该作者
经验之谈,谢谢楼主了,请继续努力
bbs.mpindo.combbs.mpindo.com
48#
发表于 2013-5-14 08:09 |只看该作者
值得收藏...
去红血丝
发表于 2013-5-17 10:50 |只看该作者
哈哈,有意思。
盆景交易在线 car
发表于 2013-5-19 20:46 |只看该作者
这么强,支持楼主,佩服
牛尔晚安冻膜
GMT+8, 2026-3-18 18:33 , Processed in 0.115081 second(s), 11 queries .
